H&R Experience
Stugolf1
H&R Experience
Post by Stugolf1 »
Hi guys considering purchasing some lowering springs to take the edge off the high stance on my Gti, I have 2 high options -30mm ones or -45mm ones basically, I want to fit 18s to the car so concerned the lower type will be a bit too low without rubbing?
Does anyone have any experience with these? Or low Gti's?
LocoPolo70
Re: H&R Experience
Post by LocoPolo70 »
Hi m8....i have the 25/40 on mine because am also fitting 18 in about 2 weeks time...i have a friend who has the deeper version and when he put on 18's got a bit of rubbing...he since has changed to the 25/40 and has had no problems to date. He is running 215/35/18 et35.
Deako
Re: H&R Experience
Post by Deako »
Are you referring to the 35/55 which on the GTI actually works out to 25/40?
Stugolf1
Re: H&R Experience
Post by Stugolf1 »
According to Awesome they have a normal version 20mm front 30mm rear and a lower version 30mm front and 45mm rear so unsure :?:
LocoPolo70
Re: H&R Experience
yes it will be the 20/30 which used to be 25/40...part nr.28977-2
http://www.h-r.com/gb/f_produktsuche.php
gavs
Re: H&R Experience
Post by gavs »
If you're going with 18's, then either will be fine, the 17's get lost in the guards with the lowering springs unfortunately and it looks......Odd.....
Stugolf1
Re: H&R Experience
Post by Stugolf1 »
So the new 30/45 is equivalent to the 25/40?
