Static Cornering Fog Lights
jlwood92
Post by jlwood92 »
Just picked up my polo match. Is it possible to enable static cornering lights with a VCDS? If so how and where is the cheapest way to buy one
Malcolm Scott
Drives: 2010 (60) 1.2 SEL TSI
Re: Static Cornering Fog Lights
Post by Malcolm Scott »
I don't think this is a straightforward coding job.
To the best of my knowledge the fogs with cornering function have two separate bulbs & bulb housings - one for fog and one for the cornering function.
The latter space is utilised on the BlueMotion for the DRL's.
The Sheriff
Post by The Sheriff »
sorry mate not possible with only VCDS
jlwood92
Post by jlwood92 »
The Sheriff wrote:sorry mate not possible with only VCDS
That sucks :( looks like my fogs are gonna be permenently on then. What about setting DRL as fogs. Is this not possible in a standard Polo Match?
CANDYMAN
Post by CANDYMAN »
Malcolm Scott wrote:I don't think this is a straightforward coding job.
Hiya
i have cornering lights :D there is only 1 bulb in each housing! It is the fog bulb that illumunates. I think only the bluemotion has 2 bulbs in each lamp.
Why would your fogs be on permanently??
BlackSEL
Post by BlackSEL »
Hiya
Exactly the same in mine, one bulb and static cornering. If you haven't got a bluemotion it will be the headlights on all the time not the fogs.
