Does anyone know how to remove the cd player?
PHILthePOWER 90
Post by PHILthePOWER 90 »
As listed does anyone know how i remove my cd player?
sorry for bad quality pic using my phone.
SamF15
Re: Does anyone know how to remove the cd player?
Post by SamF15 »
As you can see there is a surround around the CD Player, just simply use a pryer or in my case a screw driver, put a bit of masking tape over it so you don't scratch it and simple put it inbetween the surround and rubber dash and just pry it out, you'll hear it pop off the clips and just do this until its free, then there are 4 torx screws holding the headunit in, undo them and it just slides out. :)
PHILthePOWER 90
SamF15 wrote:As you can see there is a surround around the CD Player, just simply use a pryer or in my case a screw driver, put a bit of masking tape over it so you don't scratch it and simple put it inbetween the surround and rubber dash and just pry it out, you'll hear it pop off the clips and just do this until its free, then there are 4 torx screws holding the headunit in, undo them and it just slides out. :)
Nice one mate ill try tomorow :)
