Changing rear indicator bulb?
- jamesagordon
Anyone know how to access the bulbs? I wanna change my indicators to chrome bulbs to clean up the light but I've no idea how to remove them, I've checked in the boot and the only access is too high up and i can't work it out?!
mozzapologti
Re: Changing rear indicator bulb?
you have to remove the light m8 and all bulbs are on a holder and come out together you will see what i mean if you take light cluster out
Hiya mate i have done mine. Yes you have to pull back the little carpet flap, then unscrew the retaining nut it is tight. DONT DROP IT. Pull the rear light cluster forward slightly and then unplug. Open the rear section of the light and change the bulb, then put it back together in the reverse order.
- jamesagordon
cheers buddy I'll give it a try!
