Much difference need help!!
quinnygti
Re: Much difference need help!!
Post by quinnygti »
get that kn filter kit and then it makes the dumpvalve real noisey
Crippin
Post by Crippin »
Why does everybody rave off the 4bar fuel regs? Surely they wont make that big of a difference unless your running a hell of a big power. Having one on a 150-230 horse polo won't really benefit anything spectacular and wont it just use more fuel? I think?
SA57.DUB
Post by SA57.DUB »
The 4 bar fpr is recquired for Revo stage 2, which is what most peole are going for. It's not so much raving about the 4 bar fpr, it's fitted along with stage 2 software and I think people are more raving bout the stage 2.
Turbomier
Post by Turbomier »
it's the diffrence between not getting past 220Hp and do reach 240Hp, in my case.
i also tried custom mapping it without the 4bar FPR but the car just won't get enough fuel and the injectors were running at max capacity.
so that is sorted out with higher fuel pressure.
even better is just get bigger injectors, but it's more expensive.
you won't make that much more Hp with injectors but it will be a tiny bit safer also.
better stick with 3bar, 4bar is more pressure, more pressure is more heat, and heat is the thing we don't want.
more heat = less power.
ok, i admit it's a tiny detail, but one thats important to remember :wink:
Crippin
Post by Crippin »
Turbomier wrote:it's the diffrence between not getting past 220Hp and do reach 240Hp, in my case.
I like your reply. You've shed a little more light on my uneducated brain.
lukey GTI
Post by lukey GTI »
Chris.T_pologti wrote:I pulled the under bonnet lining off and u can hear it so much more!! It scares kids wen i change :p haha
Ha I mite do that this weekend :p
Sent using tapatalk
Turbomier
Post by Turbomier »
Sent using tapatalk
u mean the insulation under the bonnet??
also did that uit some time ago, it does make it sound good (i did it for weight savings but it's lighter as i thought it would be so pretty useless to remove it :lol: )
rover220
Post by rover220 »
just watch the paint doenst suffer if you remove the insulation, the engine bay can get crazy hot and melt the paint off from the inside out.
drennan
Post by drennan »
Anyone done this and had a noticable differance. I run with the seal off and thats much louder than when its on
Turbomier
Post by Turbomier »
i have it removed for about 2 years now, never had any problems with heat.
and i've been on the nurburgring when it was 28C so i don't think it might form a problem, but a good point to look after, never know..! :wink:
Tsineas
Post by Tsineas »
Chris.T_pologti wrote:Afternoon guys i need your help!! I have a 9n3 gti with:
.Full milltek turbo back
.Forge front mount intercooler
.Split-r dump valve even though it annoys me
. Bigger air intake with panel filter
. Revo stage one map
I have just ordered a turbo intake pipe so that will be going on asap! My question is i have got all the mods to go for stage 2 but is the any point me forking out extra cash for bot much gain?? In not fussed about fuel or what not just dont want to build my hopes up and think its gunna be loads better when in reality it may not be!! Any opinion is helpful thanks chris
Have been riding on stage 2 Revo about 2 weeks and its awesome I cant tell you that! My friends call it monster polo! You mess with everyone up to 250hp at least! :twisted: :twisted:
Do you have a picture of your engine bay with that kit installed please? 8)
lukey GTI
Post by lukey GTI »
drennan wrote:Anyone done this and had a noticable differance. I run with the seal off and thats much louder than when its on
Which seal do you mean ?
Sent using tapatalk
drennan
Post by drennan »
Thats not mine but same intake cant find the pics of mine
Tsineas
Post by Tsineas »
drennan wrote:
Okey looks nice, but isnt supposed when having cone filter to put it inside the half OEM airbox to prevent heatsoak + PD160 ?
What about this guys? Anyone in here done it ? Works? What about Maf sensor position?
Looks like a bmc filter!
