What psi do standard 9n3's boost
Matt_27
Post by Matt_27 »
Hi was just woundering if anyone knows what psi the 9n3 runs standard?
Thanks.
Tsineas
Re: What psi do standard 9n3's boost
Post by Tsineas »
Stock boost peaks at 7psi(about 0.5 BAR).
Turbomier
Post by Turbomier »
correct!
logged mine while it was stock and it was spot on 0.5bar :wink:
Matt_27
Post by Matt_27 »
Ok thanks I was just woundering as I'm runnin a forge 007p valve with a yellow spring as I was told this is what I'd need for remap, I also have a k&n 57i induction. It doesn't chatter very often it just releases the pressure in one go when comming off boost but yet a friends chatters all the time does anyone know why this is?
Is it because of the valve I'm runnin?
Tsineas
Post by Tsineas »
From Forge website!
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
The above figures are estimates only and should only be considered as a guideline
Please note - fitting a stronger spring into a valve will not increase boost pressure unless existing pressure is being lost. Failure to allow the valve to operate by installing a spring which is to strong may cause damage to the turbocharger.
So Green = Standard Boost !
Green with spacers = stage 1 depends on your software!
Yellow = Remap Stage like stage 2 apr revo etc! / [Extreme stage 1(?)]
Should be like that!
EDIT: Link dint work! Search Valve Spring Tuning Kit @ Forges Website!
Turbomier
Post by Turbomier »
and still it's not so correct...
i must use blue or red spring (i now have blue, red is slightly to heavy), with all the rest it's opening to soon :| (stage 2)
Tsineas
Post by Tsineas »
Turbomier wrote:and still it's not so correct...
Then use blue with some spacers to adjust right?
Allthough you don´r run Revo 2, you got some custom ecu done if I´m not mistaken with really high boost almost tops it?
Matt_27
Post by Matt_27 »
Well I'm goin to get stage 2 done soon so I should be ok wiv the valve I've got or do I need to change it for a green spring
Tsineas
Post by Tsineas »
Matt_27 wrote:Well I'm goin to get stage 2 done soon so I should be ok wiv the valve I've got or do I need to change it for a green spring
Forge Website wrote:Please note - fitting a stronger spring into a valve will not increase boost pressure unless existing pressure is being lost. Failure to allow the valve to operate by installing a spring which is to strong may cause damage to the turbocharger.
Crippin
Post by Crippin »
Mine seems to be around 9psi. Standard car except miltek exhaust, replacement filter and a recirc valve..
Tsineas
Post by Tsineas »
Crippin wrote:Mine seems to be around 9psi. Standard car except miltek exhaust, replacement filter and a recirc valve..
The answer is there! :D
Matt_27
Post by Matt_27 »
Ok thanks for your help
