Standard grill removal?
i know i might be acting stupid here but how on earth do i remove the standard grill on the 6R (top grill) i undone the 2 screws at top and then looked for others and seen none but it just didn't want to budge haha
Re: Standard grill removal?
im having the same problem, i also want to carbon wrap the front and back badges
any ideas??
any ideas??
- Boyracer_2011
- Drives: 1.2 Moda
Once you've undone the screws, theirs about four clips on the bottom of the grill you might need a flat screw driver to help them out. Just take ya time tho mate.jakovdub wrote:i know i might be acting stupid here but how on earth do i remove the standard grill on the 6R (top grill) i undone the 2 screws at top and then looked for others and seen none but it just didn't want to budge haha
Boyracer_2011 wrote:finally someone replied haha cheers bud, i'm gunna give it a go tomorrow to try out the red & black themejakovdub wrote:i know i might be acting stupid here but how on earth do i remove the standard grill on the 6R (top grill) i undone the 2 screws at top and then looked for others and seen none but it just didn't want to budge haha
Look at the pic below and apart from the two screw holes you will see 4 clips. Each of these clips fits into a slot and latches into place. To undo them you need to press the clips down. For each clip there is a rectangular hole to put a flathead screwdriver into to release them. I put electrical tape over the screwdriver to protect the plastic clips.
You need to firmly pull each of these clips out of their slots. Once they are all out you can get access to the lower inside part of the grille. This will enable you to pull upwards on the lower clips to remove the grille completely. If I remember right there are 4 or 5 lower clips.
