Brake Light Switch - EPC Light
adzpz
Post by adzpz »
My EPC light has come on the dash - I have checked and my brake lights aren't coming on :(
Please can someone talk me through how to remove the switch on the brake pedal (it looks fragile) or post a link to a guide?
I assume this is the most likely cause for the fault?
Thanks in advance.
Dom_
Re: Brake Light Switch - EPC Light
Post by Dom_ »
They usually just twist and pull out!
Will be similar to this I would imagine, never done a 9n3 one
http://forums.vwvortex.com/showthread.p ... ing-it!%29
adzpz
Post by adzpz »
Thanks - Ideal! It's the same only in brown.
Next problem is GSF don't have any in stock - where else can I buy them online or it's off to the stealers?
Dom_
Post by Dom_ »
EuroCarParts should do them, TPS is only other option if you want a genuine one but you can't buy online from them
benmkiv
Post by benmkiv »
Stealers aren't expensive man. I got a brake light switch from them for £9 I was shocked at how cheap.
