mine has damage from someone jacking on the sill (where the rubber grommit is) and further in along the ridge under the the sill.
Jacking point!
Jacking point!
Where is best to jack on the Gti?
Re: Jacking point!
There should be a point at either end of the sill under the skirt where the metal is re-enforced. A section where it is almost twice as thick. It's very near each end and should be easily identified.
Re: Jacking point!
If jacking the rear, go under where the shock meets the axle on a block of wood
If jacking the front, go under the wishbone lower bolt with a block of wood
Safest way, with no damage
