[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 My 6 Speed GTi Powered 6n2 - UK-POLOS.NET - THE VW Polo Forum
Cant find a welcome thread so will just put it here. a few on here will already know my car but for the rest it started as a 2002 1.4 match, now running gti engine, 6 speed box.
bought her like this
to this
Bit beading
still got loads to do, exhaust, gti rear axel, headlight washers then xenons and get the auto headlight levelers to work.
Well postman delivered a couple of pressies today, so eventually going to get on with the exhaust, coupling these up to a mongoose centre pipe i believe you 6N2 GTI 00 used to own, as it came from Mandy's car, dont know if the backbox will survive as its being attacked with a angle grinder as didnt want twin pipes. going to get two new lamba nuts fabricated so i can get lamba's in correct position, decat pipe will be cut to insert the sport Cat.
Well, put the exhaust on and took it back off three days later, problems with front exhaust hangers being wrong for my car as I am not running a polo subframe, this had a knock on effect with the centre box sitting too high and fouling my heat shields too, so vibrations and knocking as it was fouling my roll bar too, another non polo item, so knocked pre cat out of standard down pipe and refitted complete standard pipe. so this 4-1 decat pipe and cat is up for sale. have also just bought another set of coilovers so will hopefully get a these and axle fitted soon as ive got a few days off coming up. exhaust will have to wait till i can afford a custom jobbie.
Well not done much lately, fitted GTi steering wheel, dyed carpet, needs doing again as only had half a litre but looks much better, pics don't really show it as it was too sunny (my s**t camera hates the sun lol). and Ive also got round to painting my gti calipers and carriers blue so fitted them as-well, when I striped brakes down there were shagged so put disks and pads on that came with calipers when I bought gti rear axle, they had some surface rust but were almost new. Also sorted out my engine cover as one of the slide clips snapped, not much of a update but took most of the day.
Got another set of coilovers but need my arches rolling first.
TRiBaL wrote:Great job!
It will look a lot better if you fit a color coded gti splitter. It is a must in my opinion
You should also consider a short antenna, rear wiper removal for cleaner look and a tailgate spoiler.
I have a short Arial, must fit. I also have a gti spoiler but against fitting it as I think it will spoil the lines, dont want a gti splitter, although colour coded might be Ok. will never loose the rear wiper though I am going to upgrade it to something less ugly, I dont want it to look like a GTi cos its not and in my opinion its better, there are much better with 6 gears and box is less problematic too, But cheers for the input.
Ill keep an eye out for a splitter since you insist , paintwork was horrible when I got it but Ive spent quite a bit time on it, and stil got a bit to go, the best thing I found was that Harly wax, that last pic was just car washed dried and tyres dressed, its not been waxed for over 2 month.
Cheers for the comments
Ill have the spoiler off your hands if you wana sell
