Millers 75W90 Gearbox Oil
BBBaboonface
Re: Millers 75W90 Gearbox Oil
Post by BBBaboonface »
Hey there, thankyou Alex. Can be a labour of love with these cars, so pretty though! and well specced. Anyway im dragging this thread away from the point, so i will shut the hell up, thanks again! 8)
georgen
Post by georgen »
alexperkins wrote:Have you got a TPS price on it?
Nope, same problem, same bearings - just another gear.
I thought it was 3.4 litres as I had to get 4 bottles....but I may be getting confused with the Mk3
The lupo 6 speed box is totally different to the polo 5 speed, dont get me wrong you can still break them but are more hardy than the polo box.
fitment is different, hydro clutch and a different diff and 6 gears that are shorter, so my 6th is like a polo's 5th.
BBBaboonface
I read that the engines have the same internals and characteristics, but the block casting is different. There are six speed sequentials out there, but 12 grand is a bit of a hefty price to pay! Most companies probably wont see a return in making complex aftermarket parts for cars with such a limited production run, so they dont bother. if i win the lottery i will get a super strong six speed produced! :)
alexperkins
Site Admin
Post by alexperkins »
Just to add something i Found out today
VW OEM oil is infact FULLY synthetic therefore unless its cheaper, OEM is the best option.
BBBaboonface
Cheers Alex, probably saved me a pretty penny! :D
georgen
Post by georgen »
You are right on the engine side, but as I said the gearbox is a completely different unit to the polo. the loop 6 speed is a 02T box.
BBBaboonface
Its possible to do a loop GTI engine, gearbox, clutch transplant, is it not? Dont really see the advantage though, apart from a smoother clutch, especially considering the ratios you mentioned. May as well go the 1.8T route, surely a more common engine? mmmn 1.8Teeee (Homer simpson gargle) did anyone see Bobaturbo on you tube? its a 4wd mk2 golf but 1.8T, 1013hp Crazy fast! Soo er gearbox oil then? sorry! :lol:
georgen
Post by georgen »
BBBaboonface wrote:Its possible to do a loop GTI engine, gearbox, clutch transplant, is it not? Dont really see the advantage though, apart from a smoother clutch, especially considering the ratios you mentioned. May as well go the 1.8T route, surely a more common engine? mmmn 1.8Teeee (Homer simpson gargle) did anyone see Bobaturbo on you tube? its a 4wd mk2 golf but 1.8T, 1013hp Crazy fast! Soo er gearbox oil then? sorry! :lol:
Yes its possible, look at my avatar :D .
BBBaboonface
Niiice! 8) sorry dont mean any offence there Georgen! should look around a bit more before letting my fingers flap up and down! :oops: Do you get better fuel economy? gearbox oil, gearbox oil! still relevant now, yesss! :lol:
georgen
Post by georgen »
BBBaboonface wrote:Niiice! 8) sorry dont mean any offence there Georgen! should look around a bit more before letting my fingers flap up and down! :oops: Do you get better fuel economy? gearbox oil, gearbox oil! still relevant now, yesss! :lol:
Lol no, prob worse economy as 6th same as your 5th, I can drive at 30 mph no problem in 6th and still pull on smoothly, advantages are I dont have a box made from chocolate and when I open her up she doesnt bog down as gears are closer, so much fun to be had and a lot of faster cars get a suprise :D
BBBaboonface
Quality. Sounds ace! :D 8)
