6N2 Project (Big update)
Re: 6NZ RED
What's the tick?
Dalescottfk
Re: 6NZ RED
The hazard tick is constant but faster than it would be when indicating or the hazards are on. Still indicates fine, hazards are fine, just ticks constantly. First thought was the relay but I've been told if I replace the indicator stalk that it'll solve the problem. Picked one up from a scrappy the other day so I'll hopefully get it replaced in the next week or so
Re: 6NZ RED
It could well be
Stalk isn't hard to change
You just need to pop the battery off, very gently release the airbag clips - it's easy to do
Then three screws and its off
Dalescottfk
Re: 6NZ RED
Might have a look at it tonight then...
Re: 6NZ RED
alexperkins wrote:It could well be
Air bag removal is easy when you know how, its one of those things when you dont, it either comes off in 30 seconds or my first one 3 attempts over three days
Dalescottfk
Re: 6NZ RED
IMAG0309 by Dalescottfk, on Flickr
Considering Selling:
Volkswagen Polo
6NZ 51 Plate
3 Door
!.0 MPI
Pioneer Headunit with 6 Disc Changing
4x4 Speakers installed in Parcelchelf
112 500 miles
Debadged
Dewipered
Recently serviced:
New Bosch Spark plugs
New Castrol Syntec Oil
New oil filter
New front discs
New front brake pads
Pedalbox has been rewelded by a professional welder and fabricator
Rear drums have been serviced
Brakes Bled
Recent tires front and rear
MOT until April 2013
All advisories have now been repaired
Tax has just ran out
Car is washed and polished at least once a week and is always spotless inside
Only two issues:
Front right spring has snapped, in the process of getting a new spring and repairing it
Constant hazard tick
Hazards work fine, indicators work fine.
I have a new stalk to replace the current one, just haven't gotten around to replacing it.
Re: 6NZ RED
I probably have a front spring somewhere if you need one
Dalescottfk
Re: 6NZ RED
Spring is sorted now, still waiting on my registration documents coming through from the DVLA so I can get road tax, so it's off the road at the moment.
Looks like the backbox is gone, not sure if there's maybe more problems with the exhaust. Anybody have a backbox or know of a decent cheap one?
Dalescottfk
Re: 6NZ RED
Spring replaced.
New exhaust centre sections and tail section and back box. (Was rusted to pieces)
6 months tax
H7 HID kit installed today
LED white sidelights
6 months tax
Dalescottfk
Re: Flash Red 6N2
Vw Polo 6n2 by Dalescottfk, on Flickr
Clean.
Dalescottfk
Re: Flash Red 6N2
Look for some recommendations for a central locking kit, looking to convert my manual locks to central locking with a remote key. Also looking to find out how complicated this is to install?,
x-luke-b-x
Re: Flash Red 6N2
without a doubt it has to be this kit.Dalescottfk wrote:Look for some recommendations for a central locking kit, looking to convert my manual locks to central locking with a remote key. Also looking to find out how complicated this is to install?,
http://www.rclick.co.uk/product_info.ph ... cts_id=399
ths is by far the most popular kit used by polo, its pretty easy to install the hardest part for me was getting the wires through the tube what goes to the door
the key looks VERY oem aswell
Dalescottfk
PROBLEMS (6n2project)
Right, I have loads of updates to post but before that I have a problem... I had slight positive camber on my front right wheel for a while and it was causing tyre wear on the outside, fitted new coilovers, top mounts and bearings, rear bushes and track rod ends last night and now it's has seeerious negative camber on the front right... Ideas? I thought the positive was because the track rod end was gubbed but that hasn't sorted it... The coilovers were measured before they went on so they're the same height left and right yet it looks really uneven, must be the camber, ideas?
Re: PROBLEMS (6n2project)
Coilovers have to often be readjusted after fitting as they settle
Measuring before fitting isnt a true measurement of height due to differences in spring tolerance etc.
Check the track rod ends are fitted to the correct sides, and that the ball joints are for the polo and not the lupo as they are ever so slightly different.
Dalescottfk
Yeah I know that, that's why the height isn't adjusted to exactly what I want it to sit at yet but there still shouldn't be that much of a difference, I imagine the track rod ends are fitted to the correct sides since there are no problems with the front left and it sits fine, ball joints were never changed and the parts I have are 100% for the 6n2 as far as I'm aware
