rear interior lights gti 6r
trigg123
Post by trigg123 »
Hi
Can anyone tell me how to remove the rear set of interior roof lights in a new gti 6r? does it just pull out and is tight?
regards Trigg
CANDYMAN
Re: rear interior lights gti 6r
Post by CANDYMAN »
Hiya i have had a look on elsawin and it looks like you pop the lens out not the complete lamp.
It shows it as where the central twist switch is you slide a thin tool in the flat parts after the curve if that makes sense?
trigg123
Post by trigg123 »
cheers for that.....will have a look later :-)
trigg123
Post by trigg123 »
cheers done it.it is tricky there are 4 posts with lugs inside the lense about 5mm from the corner.slide something inbetween the lense and the black surround drag towards the corner and lever out......and no breakage!! 2x 36mm festoons await you....all for the love of leds!!!!
CANDYMAN
Post by CANDYMAN »
Are they 36mm or 39mm leds???
trigg123
Post by trigg123 »
you didnt read that last post properly did you ...lol 36mm mate......:-)
CANDYMAN
Post by CANDYMAN »
Haha yeah i did just someone said they were 39mm just wanted to check. :D
