Ive worked with a friend to make replacement parts for the headlight leveller brackets that often break on 6N2 headlights. This is what causes the beam to point to the floor, and is responsible for a variety of MOT failures.
It can happen over time, or if the headlight experiences any kind of knock or shock, this can cause it too.
This can save a costly replacement headlight from being purchased. The new ones are made out of aluminium as pictured below and are a direct swap for the inferior plastic items used from the factory. They are easily fitted by removing the back of the headlight and unscrewing the damaged bracket, then screwing the replacement bracket in.
These are the brackets that the leveller motor ball connects into
They can be purchased from Gregg via eBay here
http://www.ebay.co.uk/itm/Audi-A3-S3-VW ... 3a97327cbc
If the aluminium ones are unavailable, another company reproduces them in a stronger plastic which wont break, plus they give a lifetime warranty
See here http://www.ebay.co.uk/itm/Audi-A3-S3-VW ... 1441932085
And also available now from here
http://www.ebay.co.uk/itm/Volkswagen-Po ... 33a8df31ee
