Looks very nice & clean! What mileage is it on? How did you lower it the 30mm? Are you happy with the height and ride quality? I ideally would like some coilovers, but won't have the money for those for a long time. I seriously need to lower it though!
Aquavalver wrote:Looks very nice & clean! What mileage is it on? How did you lower it the 30mm? Are you happy with the height and ride quality? I ideally would like some coilovers, but won't have the money for those for a long time. I seriously need to lower it though!
Its got 105k on it now had 92k when I got it.
When I first had the car it had been lowered on 60mm front 40mm rear on uprated shocks/lowering springs which personally was too low for me scraped so often and speed bumps were a nightmare, passengers in the back wernt good either! I ended up getting some 30mm spax lowering springs to raise it up no problems now at all and looks good in my opinion. Rides quite firm but as I have never driven the car with the original suspension I cant really compare it.
I would of liked coilovers too but also on a bit of a budget!
t.small wrote:Looks good Will. Got a clean set of RX2s on there as well
Cheers mate Yeah there not bad by no means perfect but compared to some sets I have seen there quite good. The only thing I have done is replace the centre caps, one wheel had a really corroded lip so I split it and polished up the rim.
Nice example there, very interested in the subtle lows! Was thinking along similar lines myself, and yours looks very nice on the 30mm. Top work on the rims too!
One of the small things I've done is freshen up the brakes a bit, after 12 years they were showing there age a bit...
After a couple of coats had them looking like this...
t.small wrote:Excellent work on that rim, the job you've done looks great.
BBBaboonface wrote:Nice example there, very interested in the subtle lows! Was thinking along similar lines myself, and yours looks very nice on the 30mm. Top work on the rims too!
