1.4 and 1.9 tdi exhausts the same?
hartge
Post by hartge »
Hi guys, as title does anyone know if they are the same exhaust or different?
hartge
Re: 1.4 and 1.9 tdi exhausts the same?
Post by hartge »
part numbers look to be the same from what i can see on Vag part site.
RITCHAT
Post by RITCHAT »
Identical bar the down pipe.
hartge
Post by hartge »
Spoke to my friend at the garage said they were different.
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
they are different as the 1.4 tdi is a 3 cylinder..
that said i got the silencer removed on mine and quite pleased with the sound it makes!
hartge
Post by hartge »
im just trying to get an oem one again as the one i have on now is abit too boomy
umar-dub
Post by umar-dub »
Different exhausts i think
I also tried putting the Polo GTI exhasut on my 1.4 TDI i couldnt get it to fit and neither could the garage.. Crap thing is i went and bought the rear GTI lip spoiler which has the cut out and now you can see the crappy stock exhaust :(
greypolo9n3
umar-dub wrote:Different exhausts i think
Just get a box made for the rear and put tips on..dont need to do the full thing
RITCHAT
Post by RITCHAT »
I have a gti back box fitted to my 9n 1.4 tdi. there is a difference in diameter of half a mm this was easily over come by cutting two small slits in the connecting gti rear box which allowed the pipe to go over my original pipe. I then used exhaust putty to seal and a u clip to keep it in position no problems and it looks the part.
