6n2 gti seat runners are stiff
Having problems with pushing seat front and back the seats are very very stiff ive tried grease but still no luck .any ideas
Re: 6n2 gti seat runners are stiff
I've got the same issue with mine actually.
Remove them and clean runners and seat mech then lubricate and refit.eyaaz6n2 wrote:Having problems with pushing seat front and back the seats are very very stiff ive tried grease but still no luck .any ideas
Will try cheers
TRiBaL
- Drives: 1.4 16V 6n2
I cleaned the rails and put some vaseline a year ago. Some said it would dry out soon but the seats are still moving easily.
You can buy new plastic clips that clip onto the seats and slide on the rail, they are pennies on ebay.
Example:
http://www.ebay.co.uk/itm/VW-Passat-Lup ... 1e6f91e097
They eventually wear down and sometimes even snap making it hard to move the seat.
Example:
Any ideas on how to remove the seats
Oh yeh and mine are leathers so do them clips fit in them aswell
easiest seats in world to remove. remove plastic covers off rails, there will be a single bolt or pin through the mech and the front of the seat in the middle, remove this now slide seat fully back and lift out.eyaaz6n2 wrote:Any ideas on how to remove the seats
Any ideas on how to clean the old grease off . Sugar soap ? White spirit
