Rear door seal
BlackSEL
Rear door seal
Post by BlackSEL »
Has anyone experienced a door seal issue with the rear doors on their 9n3? The problem ours has is that collects water in the gap between the seal and bodywork, so holds water that then drops out when you open the door.
Tom
Dom_
Re: Rear door seal
Post by Dom_ »
Mine nearside front door does this, as does the same door on my friends 9N...
gti-joe
Drives: 6c Polo Blue GT
Re: Rear door seal
Post by gti-joe »
Dom_ wrote:Mine nearside front door does this, as does the same door on my friends 9N...
Mine did this also, if you went round a corner or braked hard the water would come into the cabin. Took the door card off and put a bead of silicone sealant round the joint between the door and the internal metal plate and that seemed to cure the problem.
