[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 How to get sidelight bulb out? - UK-POLOS.NET - THE VW Polo Forum
This might be a stupid question but I've taken off the rubber cover. Unhooked the wee metal things. Pulled the bulb holder out..... But I can't actually pull the bulb out of the thing it's plugged into!
Are you sure you mean the side light? Because you just pull them to take it out and there is no metal harnes over it, but the main beam have the harness around them and then you have to kinda twist them put of place as there in another bracket
