9n running cold
Flattley3
9n running cold
Post by Flattley3 »
My 2003 1.4 polo 9n seems to be running cold I don't know If this is a major issue or can be solved easily I have just noticed the temp gauge hardly moves even after a long journey it doesn't sit at a normal temperature.
I also think its running a very rich mixture.
alexperkins
Site Admin
Re: 9n running cold
Post by alexperkins »
Could be a couple of things
Faulty thermostat
OR
Fault temperature sender
Id look to replace them and that should clear your problem
Flattley3
Re: 9n running cold
Post by Flattley3 »
Would it record a fault code?
alexperkins
Site Admin
Re: 9n running cold
Faulty sender would yes :)
Re: 9n running cold
One thing I would add, if the temperature sensor is only slightly faulty, then maybe there would not be any fault codes getting logged yet. Is the engine coolant (pipes etc) feel like its getting hot enough?
fonzooorooo
Re: 9n running cold
Post by fonzooorooo »
I'd change them both for what they cost.
The rich mixture bit points at a sender rather than the thermostat though. On a run, I'd expect a petrol to warm up to operating temperature even if the thermostat's stuck open.
Wiring to the plug to the temp sender can fail on these too. (ours did, then the sender failed a year or 2 later!)
Flattley3
Re: 9n running cold
Post by Flattley3 »
Do your mean sensor when you say sender? Or is the the fuel sender your talking about?
alexperkins
Site Admin
Re: 9n running cold
Sender/sensor are the same in this instance
Were talking about the temp sender
Flattley3
Re: 9n running cold
Post by Flattley3 »
Okay thanks ill try changing the temp senser and see if that works it's went before about 2 years ago. So I know where it is.
alexperkins
Site Admin
Re: 9n running cold
Be sure to use a genuine vw replacement. Copy parts often fail especially temperature sensors.
