Also i would like to know if a seat gearbox would be a good fit and would last as i know polo gearboxes are absolute pants and don't last long. any input would be great thanks
POLO 6N2 GEARBOX OPTIONS /CURE ?
ricky_noel
Hi my polo 6n2 1.4 se i believe has a gearbox problem it all goes in to gear all well and good . the problem is when the cars just ticking over and not in gear theres a strange slight grinding noise but as soon as i put the clutch in its quite ? any ideas? .
Re: POLO 6N2 GEARBOX OPTIONS /CURE ?
Could be release bearing but I think rather than messing about change the whole clutch. I would wait until it goes if money is tight though you never know it might not need replacing for sometime yet.
ricky_noel
Ok whos best to buy a clutch from maybe uprated not genuine I mean
Thatll be the clutch release bearing grinding
Its not so much the polo gearboxes - its the 085 gearboxes of this build series - they are all affected by the same problems.
Your best to get a SACHS or LUK clutch from somewhere like GSF or Euro Car Parts and get a genuine VW clutch release bearing as the quality of these is superior
If you know someone with a TPS account or have a local TPS, you can get a genuine VW clutch for not much more than GSF/Euro
To be fair, VW parts generally speaking are excellent quality and far better than pattern parts. The soft rivets that affect the polo gearboxes are just an unfortunate case of bad design.
ricky_noel
So im better off getting a different clutch that isn't genuine and a genuine release bearing ?
If you have access to a local TPS, get everything genuine
Otherwise get a non genuine clutch, but get a genuine release bearing from your local VW dealer.
ricky_noel
Ye dont have a tps im ftom jersey channel islands. Ha will get hold of a clutch from gsf or something
