Anyone near aberdeen with a GTI
Gregry254
Post by Gregry254 »
A bit of a strange post but I am looking for anyone in/around Aberdeen with a 9n3 GTI who could take me for a 2 minute spin and then jump in my car for 2 minutes.
I have a loud whining noise in first and later gears but Arnold Clark have told me its normal and to basically gtfo, a guy in work who knows a little about cars has told me he thinks its normal too but I am 100% sure something is wrong.
So basically ... is there anyone close by that can help put my mind at rest?
Simon90
Re: Anyone near aberdeen with a GTI
Post by Simon90 »
What year is the polo..
Gregry254
Post by Gregry254 »
Its a 2006.
Arnold Clark are claiming they have changed out the barings but the noise is still there ... so I doubt they did!
Simon90
Post by Simon90 »
I'm sure there's a gearbox syncro thread on here
Something to do with the early gti there was problems with the gearbox syncro's
Gregry254
Post by Gregry254 »
Yeah I read that one earlier.
That is crunching and not going into gear properly though, this is a strange whining noise that is really bad in first and more of an annoyance in later gears.
quinnygti
Post by quinnygti »
Our polos do make a wining noise in first gear. I've driven 3 and they all do m8
rover220
Post by rover220 »
yeah, 2 ive been in both have minor whine in first.
should change gear smooth though
Dom_
Post by Dom_ »
Mine does in first, and third, and fourth :?
Gregry254
Post by Gregry254 »
really? :\
I mean intrusively loud though, I am embarrassed to accelerate past like 2k in first.
I also noticed today that if I get to about 4/5k rpm in 2nd and then change to 5th it crunches on the way in. I presume that isn't normal?
rover220
Post by rover220 »
Skipping 3 gears isnt ideal.
Whine i wouldnt worry about. Any crunch between gears would concern me more.
rover220
Post by rover220 »
I would also get the gearbox oil changed as a matter of course.
Gregry254
Post by Gregry254 »
The oil was changed by Arnold Clark under warranty which made no difference and then they replaced the bearings so oil again and still no difference :(
rover220
Post by rover220 »
do you know they changed the oil for sure?
id do it yourself or get someone reputable. oil should cost under £15 from vw too as i had mine done at its last service
adzpz
Post by adzpz »
You need to use a proper syncro oil which is the correct weight - see this thread: http://www.uk-polos.net/view ... 43&t=57265
Gregry254
Post by Gregry254 »
Yeah, I went in before and the car was up on ramps with the gearbox out.
I had it inspected by a proper mechanic at the weekend and he said the gearbox is fked, its now leaking oil and they burst the boot (he pointed it out when it was on the ramps, its the black thing that connects to he back of the wheel/hub/disk not too sure how to describe it) and instead of replacing it have put sealant on, which has now burst again.
I am going back tomorrow night with the father in law and the mechanics notes to either make them fix it or give me my money back.
