Stereo problem, wireing loom? fuse?
James.watts95
Post by James.watts95 »
hello, ive just fitted a double din head unit, and it wasnt working so well so i took it out, and when i put the old (pioneer) head unit back in, it doesnt seem to work, you've got yourlive and your acc, now the problem i have is that im not getting a power thru from the acc when i turn the key to the on position, but im getting power thru fine on the live!!
can anyone shed some light on this please? ive looked for an acc fuse, but the only one i can see is the stereo, and that ones fine!
alexperkins
Site Admin
Re: Stereo problem, wireing loom? fuse?
Post by alexperkins »
It could be your ignition switch
Otherwise check the fuse for the cigarette lighter. It's on the same circuit
James.watts95
my cigarette ligher, 1 still works, and 2 works even without the key in! its hard wired to the battery i would assume!
alexperkins
Site Admin
Does you heated rear window work?
James.watts95
how do i check?
alexperkins
Site Admin
Does it light up yellow with ignition on and it pressed it.
James.watts95
yes it does! i was thinking maybe a broken wire in the loom?
alexperkins
Site Admin
Hard to say
Really, you need to test the red brown wire coming off the ignition switch when the ignition is on and see if there is 12V
James.watts95
yeah il do it over the weekend, if thats fine, is there anyway i could wire a wire from the power to the heater controls, to the acc on my iso cable?
alexperkins
Site Admin
You could but ultimately that isn't the fix. You should really work out why it's happening and fix the root cause.
James.watts95
noo, just as a temp option till ive got more time to look into it further!
alexperkins
Site Admin
Yeah as a temp just find an ignition live and use that instead.
