aww. babes. <3 xoxoxomacp wrote:Good thread enjoyed reading it and you have definitely got skills too the car looks superb.
thank you.
dunno weather to put a 1.6 in it. x
Indeed, I have the 1.4 16v 100bhp version and it is certainly packs a punch especially as it's just as fast as a lot of 1.6's such as Ford Focus's and Vauxhall Astra's.macp wrote:If you can find a 1.4 16v you will be impressed. It definitely thinks its something bigger.
Ive got a 1.6 engine babe xmacp wrote:If you can find a 1.4 16v you will be impressed. It definitely thinks its something bigger.
were did u get the aerial base from mine the same is all cracked ? thanksPiers0930 wrote:
RClick centeral locking installed, best upgrade so far, so much more easier to lock
also finished boot build now, i ported the sub to have even more bass pump out of it
Yeah a lot of modding, cutting the air con pipes on the other climatic control. not a straight swap of the controls. .James.watts95 wrote:how easy was it to fit the climate control? is it just a straight swap? or is it alot of modyfieing to do?
Dels_concept_gti wrote:hi mate i really want ti change my heater control panel i bought a climate control panel from cheapbayand was planning on fitting it. i was wrong when i removed the unit there was cables n alsorts so foooked it off as a bad job but still want to convert it few people say they have done it ! can anybody help or do it for me beer token attached
