Anyone running a seat sport intercooler setup ? Pros cons compared to forge ? Anyone know if you have to change intercooler if u upgrade to ko4 turbo ?
Sent using tapatalk
Seat sport intercooler
buzzmotorsport
Re: Seat sport intercooler
Heard lots of good things about the flow of a seat sport intercooler.
And i would say the 2" piping on the forge kit is to restrictive for a K04 Setup.
Alex
Alex
Instigator
i run seat sport IC.
and some seat guys i know have done flow tests of the seat IC VS stock and some other brands.
seat came out on top and it is capable to flow up to 350Hp.
but do not use the piping from seat, the intake side i believe it was, is flattend.
and in plastic also.
so it will mess up the "perfect flow" you want to have
also seen other tests wich had the Forge one in it.... sad to say the least.
it's good for running stock, maybe a mild chiptune in it but thats it.
it's to goddamn restrictive still and you will still get heatsoak if you get to stage II.
so let alone if you go K04
VWindahouse
We did an experimental Polo dyno day at APR headquarters in Australia last year on there new hub dyno. We put about 8 Polo's on back to back from stock to satge one to stage 2 then stage 3. We specifically monitored intake temps and graphed them up for comparison and found out of all the FMIC the Forge has the best cooling properties out of the lot. You would never get one to heatsoak. However it had the greatest pressure drop and therefore mad less power. We tried the Forge, APR, Seat and ebay coolers on the day.
Here is my dyno graph with the only difference being the Forge FMIC swapped for the SEAT with forge piping kit;
lee gti 88
Thats shows how restrictive that standard Seat set up is
VWindahouse
Totally! And that's why I got the Forge piping hit
Liking the black! Neat tidy and very subtle when fog light covers are back on
- lukey GTI
Thanks guys I think ill be going for the seat sport ic then
Sent using tapatalk
Sent using tapatalk
- lukey GTI
Found a good place to get the IC from
If anyone else is Interested
Sent using tapatalk
Sent using tapatalk
