Gearbox fitment
Gearbox fitment
Gotta change the box in my polo this weekend and I have a gear box off a mpi engine to go on will it fit straight onto the other version of the 1.4 which I think is the dohc? Might sound daft but I'm not to clued up :p
Re: Gearbox fitment
All the gearboxes are the same fitment, however some have different clutches, and each engine size has a different gearing ratio, thus if you use a 1.4 16V box on a 1.0, the acceleration is likely to not be as good as before
You should try use a gearbox from the same engine.
Re: Gearbox fitment
Both the box I'm putting in and my engine is a 1.4 so you think it should fit? I would but I'd rather spend £100 for a box from a friend than £250 for a second hand ebay jobby :p especially on £2.65 an hour XD - thanks mate
Re: Gearbox fitment
Should be ok if thats the case
- Piers0930
Re: Gearbox fitment
Alex, i've herd the TDI gearbox's are more stronger, and better for the GTI lump?
Re: Gearbox fitment
They all have the same fifth gear roller bearing and differential rivets. The only difference is the ratios
Rebuild with a metal fifth gear bearing and replace the diff rivets with titanium bolts and the box would last forever.
- Piers0930
Re: Gearbox fitment
oh right thanks alex, the gear box looks newer than the engine, from the colour of it.alexperkins wrote:They all have the same fifth gear roller bearing and differential rivets. The only difference is the ratios
Now its out, i was going to fit a new clutch, belts so i don't regret it later.
I guess i can strip it and see what has been done, as it looks like a recon.
