noise on full lock
Lukeygower
noise on full lock
When you turn the car on full lock you get a kind of crunching noise, i didnt know if this was because of the diff in the box or micanical. Also when taking a corner turning left only you get a squeeking noise but only from front drivers wheel but when you slightly touch the brake it stops, could this be dry CV joint on the shafts??
Re: noise on full lock
Possibly the s**t guard for breaks hitting wishbone. That's what mine was anyways.
Lukeygower
Yeh i didnt think of that it only clonk's about 3 or 4 times and you dont hear it again but it dont do it if your going in a straight line only on full lock. Ill get it on the ramp the weekend and try to figure out what it is
Mine does it only on full lock only started doing it after I had lowered it on h and r springs checked bushes all suspension reckon it might be anti roll bar bushes need to investigate further
Lukeygower
Ill order some just to be on the safe side if that dont fix it ill try top mounts.
Lukeygower
Where can you get the bushes from is it dealer only i can only seem to find whole roll bar kits
