Hi I'm am wondering if there is a way to change the digital speedo in the middle of the clocks for kph to mph?
Also when turning ignition off it says check safe lock but safe lock is all working? Any ideas?
Speedo
Re: Speedo
you have to use vcds you can change the kph to mph and then a quick tweek on the settings through the stalk !
ive wondered about the safe locking message but i believe that VW changed to key locking configuration one click to lock with interior monitoring and two clicks for no interior monitoring, and in doing so had to put the message on !
Re: Speedo
Yes mate done mine. As jct said you need vcds, you change the country code to australlia then through the mdi using the stalk controls.
