Dump valve
GTi_Red
Dump valve
Post by GTi_Red »
Hi , I want to put my standard air box on but keep the noise, what's the best bov to get without getting the high pitched chavvy pssssht? Also will a silicon TIP increase noise?
Stargazer
Re: Dump valve
Post by Stargazer »
The TIP won't affect noise at all. As for a dump valve I'm not sure on the exact sound it makes, YouTube might help, but the forge splitter is probably the best bet as it retains some recirculation which 1.8ts like
GTi_Red
Re: Dump valve
Post by GTi_Red »
Okk cheers think ill keep my K&n then as I like the intake noise and get a 007/008p
noone025
Re: Dump valve
Post by noone025 »
Have a look at running the 008 backwards, unless you are boosting hard you get minimal dump
GTi_Red
Re: Dump valve
Post by GTi_Red »
noone025 wrote:Have a look at running the 008 backwards, unless you are boosting hard you get minimal dump
I don't understand can you explain a bit please
