Quick Answer : Remove Rear Seats on 9n3
Tony Boi 92
Hi guys
Does anyone know how to remove the back bench on the 9n3
Tony
Tony
- Ben90
- Drives: Olympian Blue Polo TDi Sport
Re: Quick Answer : Remove Rear Seats on 9n3
Fold the rear bench down, in either far corner you'll see a metal latch with a 5mm notch in it, you use a screwdriver or similar in the notch to push the latch which releases the seat bar and lifts it up. Then slide the seat out of the other side. Repeat for the other side of the bench. HTH
- blazeguarder
And the bit you sit on is just hooked onto the floor. Fold the seat bases forwards and you'll see the metal hanger hooked into some loops which can be easily unhooked and removed.
Tony Boi 92
Solved
Thanks guys
Was pushing the latch back but wasnt sure what to do about the bit that sticks out!
Thanks again
Thanks guys
Thanks again
Tony Boi 92
andyc315 wrote:
Racecar y0
andyc315
just had a prod around my rear seats as you do
i see the 5mm notches, then what do you do with them
prodded them with my key and they seemed pretty stiff so left them alone for now
- Ben90
Push them (either forward or back) and the latch that the notch is in will retract and lift out the backrest rod at the same time, which can then be lifted out. don't worry it's sturdy!
andyc315
cheers, will have a better go tomorrow!Ben90 wrote:Push them (either forward or back) and the latch that the notch is in will retract and lift out the backrest rod at the same time, which can then be lifted out. don't worry it's sturdy!
going on a 1000 mile road trip round scotland with camping gear so want as much room and little weight as possible haha
Tony Boi 92
Come on Andy aint hard ...
andyc315
That latch... if you push it all the way back to get the bench out, if you wanted to put the seats back in how do you get the latch back out of the recess? Looks like it is going to disappear and a screwdriver can't pull it out
Sent from my GT-I9100P using Tapatalk 2
Tony Boi 92
When you put the bench back in, as the knob bit goes in, it will pull the latch back over itandyc315 wrote:That latch... if you push it all the way back to get the bench out, if you wanted to put the seats back in how do you get the latch back out of the recess? Looks like it is going to disappear and a screwdriver can't pull it out
Dont worry about that man(Y)
andyc315
Thought it might but with my luck with f*****g about with cars it would never be seen again!
Getting a bonnet bra for £22.50, don't shoot me
Tony Boi 92
Na its all good manandyc315 wrote:Thought it might but with my luck with f*****g about with cars it would never be seen again!
Not impressed
LOL
andyc315
just weighed the rear seats, middle seatbelt buckles, boot carpet and parcel shelf and they weigh a combined 29.5kg
