Rclick problem
globalomega
Re: Rclick problem
Ok sorry for spam.
Tried putting yellow wire back and lock works with that. Still no unlock. Could the fault be in white/black to white/yellow? Could it be different wire there?
Edit. Black white to white green will also lock it, so the fault is in white yellow
globalomega
Re: Rclick problem
Recheckd all connections 4 times. Tried all wire combinations, dont have a single clue why it wont unlock with remote. Probably my Polo is from different planet.
You can lock this topic, thanks for all the help.
Re: Rclick problem
Wasnt spam - was just splitting it into its own thread to keep the DIY guide clean
You may have a fault pump side - worth popping the cover off and checking all the connections are good
You may even have a faulty Rclick unit - this can happen.
globalomega
Re: Rclick problem
if i connect black/white wire ( unlock ) to white/green ( lock on pump ). I can lock the doors with unlock button on the remote. So it means that the RCL unit is fine, as far as the white/black wire.
Also, when i took the white/yellow pump wire off from the pump i could still unlock the door with the key. :/ Thought that shouldn't happen if white/yellow answers about unlocking.
Re: Rclick problem
The doors will always work to lock/unlock
This is a very strange problem you have
globalomega
Re: Rclick problem
I think it's something wrong with the white/yellow wire. I dunno how to check if it''s working properly
Re: Rclick problem
I assume you have tried connecting again with another splicer?
globalomega
Re: Rclick problem
Yea, i reconnected wires many times now.
globalomega
Re: Rclick problem
Tried to do something again with the kit. Reconnected all the wires. Now both lock and unlock buttons will lock the car.
This is getting stranger and stranger
Re: Rclick problem
I think your kit is faulty.
globalomega
Re: Rclick problem
Seams like that. How to know which locking system belongs to my car.
Re: Rclick problem
Look at the PDF guide in the first post of the DIY guide
