GT cuts and dies
GTIR 350
GT cuts and dies
Post by GTIR 350 »
Hi I have a H reg 1.3gt polo and it started to play up on its usual journey,
where it would miss a couple of times and then stall and not restart until 5 mins later, well today it cut out and would not fire for 2 hours! as this is a
total pain and I am not an polo expert has anyone got any suggestions?..
Thanks guys
Frank :(
polog40racer
Post by polog40racer »
not firing, but still turning over?
Can you hear your fuel pump prime?
Could be hall sender, or coil. Dont bother going through the expense of replacing leads and plugs, rotor arm, dizzy cap etc. No point.
Could disconnect blue temp sensor plug to distinguish between ignition fault and fuelling fault. But it does sound more ignition related and hall sender-ish due to occasional missing and failure to restart. Spray WD40, into the plugs of the coil and into the hall effect sender plug (3pin) on top of distributor.
A new hall sender is £35. This is a common problem on MK3 Polo's, along with the renowned crap Coil.
GTIR 350
Post by GTIR 350 »
Hi mate thanks for the fast reply very appreciated and informative,
I will check all those points out and thinking back when I used to own a
RS turbo the hall sender went on that very similarly!
Regards Frank :)
Tahrey1043
Post by Tahrey1043 »
whats wrong with the mk3 coil?!
dont give me extra reasons to get a fiesta or volvo now :D
robz
Post by robz »
supposedly the coil is... not the best 1 ever produced. Ive got a similar prob on my Gt but the guy who had a look at it says he thinks its the ignition switch.
*reminds me to go2 VW to but a new 1!*
hardhitter
Moderator
Post by hardhitter »
Hi mate, it does sound like an ignition oriantated problem. Like paul said investigate the dizzy/hall sender and coil. The standard mk 3 coil isnt up to much and it's definately worth replacing with a golf mk 2/3 digifant system as it perks the car up (a good mod).
I will try and organise what you were after, soon.
GTIR 350
Post by GTIR 350 »
Ok thanks Hardhitter an all looks like the hall sender may be the suspect
cost £27.50 from german and swedish going to change it in the next couple of days
Frank
Karl_CLCoupe
Post by Karl_CLCoupe »
hardhitter wrote:The standard mk 3 coil isnt up to much and it's definately worth replacing with a golf mk 2/3 digifant system as it perks the car up (a good mod).
Any partcular madels that this coil is fitted to? I'm guessing anything that isn't CL? And how easy is it to do? I simple bit of unplugging one, and installing another?
Thanks.
Karl.
hardhitter
Moderator
I will try and do a guide to the golf ignition system upgrade. Basically you are looking for the Mk 2 golf / jetta / passat or early Mk 3 golf which has digifant injection. You need the coil, amplifier and wiring to replace the crappy single unit on the polo.
hayesey
Post by hayesey »
any Golf/Jetta etc... that runs 8valve digifant. this is late mk2 golfs & some early mk3s. There is a guide to it on http://www.polog40.co.uk in the modifications section under Engine Efficiency
Karl_CLCoupe
It does mention just the GT and the G. I'm not sure therefore whether I can do it on mine. Mind you, it doesn't say you can't...
Karl.
hardhitter
Moderator
Of course you can do it. For any Mk 3 polo (excluding diesel, obviously) it will work, but you are likely to feel an improvement with a GT or G40.
GTIR 350
Post by GTIR 350 »
Well I changed the Hall sender etc and it seems okay (fingers crossed)
so Have just ordered a K&N panel filter to help it breath a little better
done this on my wifes golf gti 16v and it made a big difference :wink:
(although she sold it and bought a willy 2!)
next upgrade decat and chip when available :wink:
Frank
hardhitter
Moderator
Yes, they are available. I will try and organise meeting up next week or so, as I will have time off work and will be down your way.
Yeah, the K&N panel will help especially if you modify the air box in the right places.
