Coilovers needed!!
Coilovers needed!!
Hi all I currently have fk coilovers on my gti but unfortunately I buggerd one this morning and its now leaking so I need two fronts or even a full set any one got any? Or even recommend some half decent budget ones I would love too spend big money on some but recently bought a house and then needed a gti in my life and thennn decided to book a holiday today so funds are rather low now
any help will be much appreciated
Tony Boi 92
Re: Coilovers needed!!
Get JOM i love mine
andyc315
Re: Re: Coilovers needed!!
What did you have on your corsa?Tony Boi 92 wrote:Get JOM i love mine
How do jom ride compared to standard?
Sent from my GT-I9100P using Tapatalk 2
Tony Boi 92
Stalker muchandyc315 wrote:What did you have on your corsa?Tony Boi 92 wrote:Get JOM i love mine
FK AK on corsa
Its VERY stiff VERY uncomfortable, but im used to it from Corsa and quite frankly, i dont mind
andyc315
Ha f**k off
I had them as well, cba with that s**t again! I can't decide between ap coils or h&r springs
Tony Boi 92
Depends if you want lows or coiliesandyc315 wrote:Ha **** off
I had them as well, cba with that **** again! I can't decide between ap coils or h&r springs
andyc315
WutTony Boi 92 wrote:Depends if you want lows or coiliesandyc315 wrote:Ha **** off
Tony Boi 92
i meant lows or handling
andyc315
Dunno! I want to be able to hammer it without worrying about scrubbing but nobody can deny lows look cool as fckTony Boi 92 wrote:i meant lows or handling
Tony Boi 92
coilies then
Where did you get Jom coilovers from eBay? I can't find any
Tony Boi 92
They actually have all disappeared except the £1000 ones that have obvs been listed accidentallyPhile6802 wrote:Where did you get Jom coilovers from eBay? I can't find any
Don't suppose you could take a pic of your arch gap with the could on as awsome gti have Jom coilovers in stock but they say 55mm drop I want mine to sit where it is now with the fk coils the adjusters are about 15mm from the bottom and the helper springs are still in aswel will a get a decent drop with the joms are should I invest in some other ones? Cheers
Tony Boi 92
Check my progress thread manPhile6802 wrote:Don't suppose you could take a pic of your arch gap with the could on as awsome gti have Jom coilovers in stock but they say 55mm drop I want mine to sit where it is now with the fk coils the adjusters are about 15mm from the bottom and the helper springs are still in aswel will a get a decent drop with the joms are should I invest in some other ones? Cheers
