Hi all
Was thinking of recently about painting my calipers
Dad recommended Hammerite paint.
Anyone else done this?
Painting brake calipers
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Re: Painting brake calipers
how about brake caliper paint? lol
x2 for caliper paint
Have you two done it?
- Ben90
- Drives: Olympian Blue Polo TDi Sport
I've done mine with Hammerite direct-to-rust and the finish is still really good 5 months and many pressure washes later. The tin says '8 year protection' - if that's true it'll see the car out to the scrapheap. A small tin will be more than enough, I used less than half a tin on four calipers with two coats.
It says direct to rust but obviously you'll have to get your hands dirty with a brass-bristle brush (the ones shaped like toothbrushes are good for calipers) to remove all of the loose rust and create a smooth surface for a good finish, I used a dremel which was brilliant but don't forget face mask and goggles.
Hope this helps.
Hope this helps.
Nice! Thanks for the advise
You got any pictures?
- Ben90
In my thread mate in member's rides
Hammerite all the way!
funlovincriminal
- Drives: 6R GTI
Hammerite is fine. I've used it a few times, no real need to buy special caliper paint.
