knocking from passengers side
cam20vt
Post by cam20vt »
Hopefully someone could shed some light for me, my 08 gti has a knocking when setting off and sometimes over speed bumps or if I accidently hit a pothole (easily done where I live) , its coming from the passengers side but I cant pin point where its coming from, the car had a new gearbox mount and engine mount when I did clutch (about 2 month ago) as there was play and the engine mounting snapped about 3 week ago but its still knocking, ive checked everything I can think of and cannot find play in anything, it knocks 3 or 4 times when setting off normally and sometimes when I change into 2nd and put accelerator back on as normal any help will be much appreciated
Dom_
Re: knocking from passengers side
Post by Dom_ »
Check subframe bolts and lower arm bolts, mine were ever so slightly loose and made an awful noise when setting off
Did you change the dogbone mount too?
cam20vt
Post by cam20vt »
No the dogbone mount seemed fine when it was removed, might change just to see if it makes a difference, will check subframe bolts as soon as I get a minute, yeh its a really loud knocking when setting off, not sure how to put videos up ive got one of it knocking
Dom_
Post by Dom_ »
Sounds a lot like what mine was doing, the bolt was on a little loose but the lower arm was moving and the noise was transferring through the whole subframe making it sound really violent
cam20vt
Post by cam20vt »
Checked all the subframe bolts, not a bit of movement in any bolt all tight but still the same knocking
GTi_Red
Post by GTi_Red »
You got a cone filter on it?
cam20vt
Post by cam20vt »
No its got a foam ramair airfilter, thought it could be the base of that banging on the airbox so I removed the air box and made sure the filter was secured in place it sounds like a bush or mounting when it knocks, its really loud and easily noticeable when setting off but when its on the ramp I cant find anything at all with play its driving me mad
Stargazer
Post by Stargazer »
Have you checked the dog bone mount bolt? Mine was about 1/4 turn loose and sounded like the car was gonna fall apart lol
cam20vt
Post by cam20vt »
Yeh ive checked then bolts aswel, gonna order the dogbone mount today, one less thing it could be then
GTi_Red
Post by GTi_Red »
Bush mount bolts?
cam20vt
Post by cam20vt »
Yeh I checked the dogbone bush mount bolts they were tight and I know the engine mount bolts are tight as I did that one gonna take battery out tommorrow and check the upper gearbox mount bolts
cam20vt
Post by cam20vt »
The upper gearbox mount bolts had come ever so slightly loose, either that or the mechanic didnt tighten them properly
