Vagcom help
JasonPollock
Drives: polo
Vagcom help
Post by JasonPollock »
I feel I have exhausted the search function but still can't get the right answer. I have been playing with vagcom on my 2013 6R GTI but there are still some items I can't alter. I want to turn off the rear wiper in reverse, add the digital speedo and needle sweep, can anyone help me?
There was a thread somewhere I'm sure detailing some of these functions but I can't find it. For the digital speedo I have tried to change it to all the other country settings but with no success. Can anyone advise? I only have a lend of a genuine cable for a short period of time also :(
:D
Thanks, Jason
Wilxay
Vagcom help
Post by Wilxay »
JasonPollock
Drives: polo
Re: Vagcom help
I just spotted where I think I went wrong on the rear wiper, will give it another go now. Don't see anything about the other two Unfortunatly.
calvinw1
Re: Vagcom help
Post by calvinw1 »
, for needle sweep;
Instruments- adaptation- indicator celebration mode to "on/yes" :-)
Re: Vagcom help
Link in French with vcds modifications for many models. JasonPollock I think here is the rear wiper and the needle sweep.
http://ankk-vagcom.com/category/codages ... w_polo_6r/
CODAGES VAGCOM
JasonPollock
Drives: polo
Re: Vagcom help
Thanks, found the needle sweep and eventually figured out the digital speedo. Success.
calvinw1
Re: Vagcom help
Post by calvinw1 »
H
Glad to hear, was it celebration mode?
vedubber
Re: Vagcom help
Post by vedubber »
Where did you find the needle sweep? How did you do it in the end?
calvinw1
Re: Vagcom help
Post by calvinw1 »
Vedubber, needle sweep is located in the place I mentioned above.
vedubber
Re: Vagcom help
Post by vedubber »
It's locked out on my car :(
calvinw1
Re: Vagcom help
Post by calvinw1 »
vedubber wrote:It's locked out on my car :(
Strange! Is the "needle sweep" option blanked out as well?
chrispy.
Vagcom help
Post by chrispy. »
For needle sweep you need to have a H type cluster which i believe are only fitted into GTI's and BlueGT's
You can find out what type of cluster you have by doing a scan of your car. This will show you everything about your car and will identify which one you have.
calvinw1
Re: Vagcom help
Post by calvinw1 »
I've Set it up on 3 r lines which don't have the same cluster as either the blue gt or gti...
chrispy.
Vagcom help
Post by chrispy. »
Apologies, R-Lines do have the H type cluster
