Hi all.
I am getting a RCD510 DAB very soon which does not come with an aerial.
Does anyone know if i HAVE to use a VW OEM aerial? Or can i use a standard £10 aerial from my local store.
Thanks!
DAB Aerial. OEM vs 3PP
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Re: DAB Aerial. OEM vs 3PP
Would like to know the same thing!...i got RNS510 DAB....really confused about the ariels lol
- hornmeister
Same frequencies so should work on the same aerial. Unless you are in a patchy area in which case you may need one with a higher gain/sensitivity/aplification. It's the way the data is broadcast & decoded which is handled by the head unit itself that differs from an FM signal. In exactly the same way that a Freeview telly can pick up a signal from a good old analogue TV aeriel.
Try it with the stock aerial and if it's not up to scratch upgrade but in a strong signal area you shouldn't have any issues.
Does anyone know where they are positioned in a Polo 6R?
When i install rcd510 or rns510 with dab radio, i use the antenna from a vw multivan, along with a extension cable also from vw..
Parts are about 100£.
I place the antenna on top of the glovebox.
Sent from my Aiiiiiiightphone
- greypolo9n3
So i can get DAB antenna and extension from vw and put that on glovebox?Watcher wrote:When i install rcd510 or rns510 with dab radio, i use the antenna from a vw multivan, along with a extension cable also from vw..
And i can get shark antenna for nav and fm?
Ive got a standard aerial on my roof which i will try when i receive the RCD.
If not, i will try and alternative
greypolo9n3 wrote:So i can get DAB antenna and extension from vw and put that on glovebox?Watcher wrote:When i install rcd510 or rns510 with dab radio, i use the antenna from a vw multivan, along with a extension cable also from vw..
Yes, but remember you cant get a oem shark antenna with FM..
On mine i took one from audi a6 4f with gsm and gps and swapped the gsm connector to fm..
