After hitting the search button and not believing no hits,have decided to post my experience of fitting polybushes to the front wishbones...
Helps if you have access to a pit or ramp,three metric sockets one metric ring spanner a big hammer,chisel,holesaw and hacksaw blade,etc,etc...
Here goes...
Jack up the car/pit/ramp/axle stands,the wishbones are held each side by fourteen screws,....undo them
...the most difficult to get at are the two holding the anti-roll bar
and the upper mounting bolt
with all bolts removed yank the bugger out and transfer to bench
to remove the smaller bush you have to trim the rubber on the end to help the bush out
this is then removed by pressing or hitting with a lump hammer and drift,
the larger bush has to have the inner removed by burning,hole sawed or hacksawed and the outer shell removed by hammer and chisel
pressing the new bushes in is easy-peasey..
installation is the reverse of removal
Tighten all thirteen bolts
Half a day and £33 and job done
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0825202227
Please see note below before spending!!!!!
John
