I want some of these for my 2011 SEL Polo, is it as simple as swapping the units over? Will there be any bulb out light warnings?
http://shop.ahw-shop.de/1504-vw-led-ken ... 9c3nbrll13
Any help would be appreciated.
AJ
OEM VW LED Number Plate lights
I would also love some of this. Would like to know if they are a straight swap like you said.
Re: OEM VW LED Number Plate lights
Can confirm there a straight swap. Possible bulb warning light though.
- jammydodger
- Drives: 6R GTI
I've got a set if OEM ones installed. They make it look much more classier! It won't throw a bulb out warning as the numberplate lights aren't part of the Canbus system.
Numberplate lights are linked to the bulb warning light they just both need to be inop at the same time for it to come on
Mint Thanks for your help guys! Any ideas where is the cheapest place to source two of these?
AJ
AJ
- jammydodger
- Drives: 6R GTI
Got them from VW direct - I think they were £25 each, I remember reading somewhere that Porsche use the exact same ones and they can be had for around £15 each. Here's the ones you need - http://www.kufatec.co.uk/shop/en/Volksw ... K8943021C-
