Hi all,
I have a polo GTi lowered on bilstein B14 coilovers. A couple of months ago i started hearing a creaking/popping noise when turning the wheel at very slow speeds unto around 5mph.
My first thoughts were the top mounts/bearings, however the noise disappeared for around 3 weeks which made me believe it wasn't. Today the noise has returned so I'm just wondering what peoples thoughts may be? another idea i have had would be spring bind?
car only has 13k miles on it so i would hope the top mounts would not have d
failed already.
Thanks in advance
Creaking/Popping noise from coilovers
Re: Creaking/Popping noise from coilovers
Sounds like they are probably just coil bound. With all wet and s**t that has probably been thrown up over the winter so far.
Get under there and give them a good clean out and spray some lube around the top and bottom of the springs. This will help the spring move around on the plates as you as turning the steering wheel.
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
make sure the spring is properly seated in its groove, check your top mounts properly as it could cause it even if little worn
Tony Boi 92
This exactly happened to me and I knew exactly what it was ...
... on the top mounts, there is a bearing ...
http://www.awesomegti.com/suspension-to ... n-etc-pair
I forgot to put mine in?
Check this !
Check this !
