ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Locked
stan-the-man
Post by stan-the-man »
Mr.Ciclo,
This is absolutely correct! :D
All functions of the switch + other instruments work as normal.
I will try to find same BCM as yours and see what happens, will be very interesting to clarify for good if the BCM is the culprit!
Probably wont be easy sourcing one second hand... :cry:
Thank you again
Stan
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
I had the same problem... It's a coding issue.
Watcher coded mine so I don't remember myself what he did. But try writing to him with the problem. :)
Aszfaltbetyar
Post by Aszfaltbetyar »
Hi ciclo!
What is Your multifunction flat steering wheel exact part number?
I have 6 gear manual, like yours so i dont need the DSG version steering wheel.
stan-the-man, is very important to test that you do :D , many people in Europe (and elsewhere) will be grateful or at least should do because I believe it is very important for safe driving.
Here important info for change BCM: http://www.polo6rfreunde.de/board3-der- ... cm-update/
With BCM 7H0 937 090 the question is: Why do cut supply +30?
My BCM is 7H0 937 089 F and all lights work properly in all switch positions. The coding and installation as in my tutorial.
Aszfaltbetyar wrote:Hi ciclo!
My steering wheel is R-line standard without buttons retrofitted with what you see in the image below:
Full Steering Wheel R
5K0419091AR ASZ
Here's more information:
http://www.partsbase.org/vw/scirocco-sc ... ing-wheel/
http://www.partsbase.org/vw/golf-god-ar ... ing-wheel/
stan-the-man, do the following check with VCDS in BCM finished in 90:
In the byte 22 bit 6 marked and checked the rear fog light (rear fog switch position) and high beam in Auto (push stalk).
Now, the same but unmarked. :idea:
Please tell me what are the results.
This is the byte. (bit 6, interlock display (clutch message) in instrument cluster active)
edit
stan-the-man
Mr.Ciclo,
Only saw your question now.
Will do it as soon as I can and I will post results :)
Stan
Info:
Solder and seal with advanced waterproof function.
A good way to solder wires easily.
For example:
http://www.aliexpress.com/store/product ... 88275.html
Most used:
http://www.aliexpress.com/store/product ... 94267.html
http://www.aliexpress.com/item/10pcs-lo ... 47457.html
I have used this system and is simply perfect. :wink:
stan-the-man wrote:Mr.Ciclo,
Stan
:D
I have the solution for your BCM 7H0 937 090 for the automatic lights function properly.
The high beams would work in the AUTO position light switch.
No need to buy a BCM 7H0 937 089 F
You have a PM. :wink:
New mod VCDS:
Single LED DRL off when indicator is blinking.
09: Cent Elect---byte 23---bit 7----0->1 binary.
Mart!n-GTI-DK
I'm SO having that done on mine!!! :P
Mart!n-GTI-DK, I tried to activate the tear wiping but rejects the code. :)
Mart!n-GTI-DK
ciclo wrote:Mart!n-GTI-DK, I tried to activate the tear wiping but rejects the code. :)
Just as I said... But would be cool if it had worked. :)
Mart!n-GTI-DK
Got the lights coded. :)
Looks awesome. :P
Locked
