Hi all
I'm new on here but with the law just changing to make a check for a DPF on all MOTs compulsory.
Could I still get my 1.6 tdi 90ps remapped or is this no longer an option.
Please get back to me and let me know.
Thanks.
Remap with New *Laws*
Re: Remap with New *Laws*
You can have a map which keeps the DPF.
Brilliant. thank you. do you have any recommended places to go for it?
Pendle Performance
Very good company who care about getting a smooth power line to reduce a huge spike in power which can result is burning your clutch out.
joelburbidge
The mot check for dpf is only a visual check so you can have the filter taken out on the inside and the casing put back on I believe
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
I think joel is right..
as there is no real way of actually checking if there is a filter inside...Unless they use the vagcom feature which i dont think they will bother with
But its 99% most likely to just be a visual thing..ive had my dpf and cat removed but "visually" they are still there
Would they not be able to tell when they do the emissions test?
joelburbidge
I believe they don't emission test diesels
- greypolo9n3
they do emission test diesels..
but even all this does not hugely impact a diesel....80% of the time it passes it
Or just have a friend for an MOT tester....
