hi guys
tried changing my steering wheel to a momo and failed
couldnt get the boss on
so put my standard back on
and now have the airbag and abs lights on
how can i delete them?
9n3 ABS & Airbag Light
Re: 9n3 ABS & Airbag Light
Everything connect back up okay?
All plugs plugged in,
When my last polo was off the road i changed to a momo then swopped back but didnt have any issues that i remember maybe give it 50miles or disconnect the battery for 30mins?
If all fails vag com it haha
Tony Boi 92
well its only one cable for the air bag isnt it so bit confusedSimon90 wrote:Everything connect back up okay?
ive done the miles, ive done the time :/
how do i vagcom it as i dont wana turn off all the airbags
Tony Boi 92
I have Vagcom,h100vw wrote:VCDS is for clearing fault codes. Which if everything is connected properly and serviceable, will turn off the warning lights.
Unless you have VCDS handy, always disconnect the battery before doing airbag jobs as the controller sees everything otherwise.
Gavin
and I did disconnect the battery for the airbag removal?
How can I use Vagcom to sort this out?
Tony Boi 92
Would yu know exactly what I need to do?h100vw wrote:You log in to the airbag controller and check the faults and then clear faults. It strikes me that you need to do some poking about with VCDS, to learn it's capabilities.
There's an interactive thing on the website to show you what to do.
Gavin
Tony Boi 92
All sortedh100vw wrote:Yeah, it's dead easy but I live in Australia and as a "newbie" all my posts get vetted by mods first, so it's painful sending replies.
Honestly, you have an internet connection, which means you have google. Don't rely on asking questions on forums for answers mate.
There would be millions of times this has been asked before. If you don't have a real VCDS cable, do yourself a massive favour and get one or someone that does have one.
Gavin
So happy haha
