upgrade rear brakes
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
upgrade rear brakes
Post by greypolo9n3 »
Anyone have any idea what i need to upgrade rear brakes?.
will i be able to fit a 256mm kit straight on?
Simon90
Re: upgrade rear brakes
Post by Simon90 »
You need to modify you rear splash gaurd (thats what i call it) or remove it.. I just cut mine and its mint cant see it once discs are on anyways
greypolo9n3
Simon90 wrote:You need to modify you rear splash gaurd (thats what i call it) or remove it.. I just cut mine and its mint cant see it once discs are on anyways
i suppose thats the black bit behind the discs?...
So all i need is callipers and carriers and they bolt onto a normal polo?
Simon90
Post by Simon90 »
Pass i brought mine off a lad on here and they came off his polo so cant comment on what to get them off
Eddie9n
Post by Eddie9n »
You get them off something which is not a quattro. So the mk1 octavia vrs, Golf 4 GTI 180 and Seat Leon Cupra R. If they're off an s3 or tt they won't fit. Hardly worth the upgrade in my opinion though!
