Hi all.
I have got 1.6 tdi and I'm buying H&R 24/40 lowering springs. Which set do I need as I see 2 different weights. Thanks guys
Which springs do I need!
Re: Which springs do I need!
Can someone please reply I am wanting to get them bought and fitted soon as doing other bits before volkspower in June
JIC Cracked
I think you may need these set of springs, due to the weight of the TDI engine you have.
H&R 25mm/40mm Lowering Suspension Springs
Polo 6R 1.6TDi 06/09>
Part Number: 28977-2
Front Lowering: 25mm
Rear Lowering: 40mm
Front Axle Weight: Up to 990kg
Rear Axle Weight: Up to 840kg
Hope that helps
Rear Lowering: 40mm
Hope that helps
I wish I had waited for a reply I am like a kid in a sweet shop getting things for my car as I'm a newbie lol. I ordered ones with 930kg front axle load as I found info only car on the net saying that was correct. I really hope it is. If it is not correct will I not be able to use them? I don't realise what it means.
- jammydodger
- Drives: 6R GTI
Have a read of this... Sounds a little worrying to be honest.
Check out this link. It says that my car is 930kg.
http://www.rezulteo-tyres.co.uk/tyres-f ... 1.6-tdi-90
What are other peoples views after looking at this link. Thanks guys.
It also says 930kg on the sticker on the inside of my drivers door. So have I ordered the correct ones
