6n2 rear weel abs sensor replacement
sjpope78
Post by sjpope78 »
As above has mine scanned and it has come up sayin both rear wheel sensors faulty, the mechanic that scanned it ( owns the garage family friend) says he doesnt think that they would both be faulty its prob a wiring issue, which i know is under the rear bench, for the price of the sensors £7 each is it worth trying that 1st?? If so are they a b***h to get out ive heard they can be?
cheers for and help gys
Simon
alexperkins
Site Admin
Re: 6n2 rear weel abs sensor replacement
Post by alexperkins »
Its unlikely they are both faulty together. Check the connections under the rear bench, then check the connections at the wheels
They are pretty difficult to get out - normally the bolts snap and have to be drilled out. If you do remove it, you need to use a good penetrating spray on the bolts that hold the sensors in first to loosen it up.
sjpope78
Post by sjpope78 »
Once ive got the rear bench up there is the black cover with wires coming out, what wires are for the abs sensors??
alexperkins
Site Admin
Theres a wire that goes left and a wire that goes right - both have connector plugs on them, and go through rubber grommits. These are the ABS wires.
sjpope78
Post by sjpope78 »
ok thanks and these will be found once i unscrew the black cover? , as i have noticed wires that run near the seat belt clips that have black conectors also, what are these??
alexperkins
Site Admin
No, the black cover is for the fuel pump
Take a picture and ill point out which is which
sjpope78
Post by sjpope78 »
ok leave it with me, once ive taken the pic ill pm you it
