problems!!!!
Discuss In Car Entertainment
niks
problems!!!!
Post by niks »
hey guys hooked the sub up and connected everything but im finding it keeps draining the battery. I wake up and the batteries just dead. Also had this problem with fitting a new headunit, im sure i got the connections correct!!!
whats the problem and how did you lot get round it????
its an alpine headunit and a vibe sub 300w amp
cheers
KarlM
Post by KarlM »
I'm presuming that the battery in your car is the one it left the factory with? so its a couple of years old.
Sounds to me like its just come to the end of its life. there could be other implications (like a faulty alternator not charging it up) but the most likely is a dead battery (especially if its over 5 years old).
Most batteries will last a bit longer than this but if you start putting a drain on it (ie the sub/amp) you shorten the life of it.
metz
Moderator
Post by metz »
Drive round with the lights and radio for an hour or so, if the car starts when u get back i'd say the alternator is charging fine, so it will just be the battery that has come to the end of its life.
I had a simular problem with a previous car (ford...urghggh) but on mine it was some diode in the alternator.
simon pope
Post by simon pope »
have u checked that ta remote lead actually works iff not it will give constant power, i have hads to put an inline switch in mine to stop this happening, could be ya problem!!!!!
carmadaaron
Post by carmadaaron »
or try one of those capacitor things
cant remem what its real name is :roll:
KarlM
Post by KarlM »
Power Caps.
They are good for suppling power in short bursts to subs when they draw more current (drop a lower bass note)
They work by taking a small charge and storing it - when a big note is played they release the stored charge.
They wont really work in this situation because they will add a additional small consistant drain to the battery. You would need one of these if your lights were dimming
niks
Post by niks »
cheers boys recon its the radio cause all the trouble started after i installed it. cause once i unplugged that and unpugged the sub current was back to normal around the battery when ignition off.
has anyone checked if current was running when the iginitons off and keys out. Checked mine yesterday and getting something like 39 on the reader so somethings draining it!!!!!
david burton
Post by david burton »
SOunds like the "remote" wire is constantly on to me?
but i guess that would be too simple! :oops:
simon pope
go into ya local halfords or wot eva is near u and buy a cheap switch cut the remote wire put the inline swith in and see wot happens if it stops there's ya problem!!!!!!!
david burton
I'g get a cheap mulitmeter from maplin first - then test the voltages in the wires....
simon pope
remembering that the remote wire carries hardly and voltage its just a small signal, the best way would be to use a light detector u know the ones where u have a srew driver tipe jobbie with 2 wires neg and pos connect the neg to the body and the pos to the remote wire with the ignition on if the light comes on u have a current, then try it again with ignition off if the light doesnt come on then u are all good!!!!!! hope this helps
wul3er
Post by wul3er »
Is the stereo definatley switching off when you pull the keys out the ignition.
Have you tried swaping the red and yellow wires around
niks
Post by niks »
the stereo connected by iso blocks which i think is just straight forward the possible reasons i think could be:
1. got my wiring totally wrong (dont think so )
2. the remote lead is faulty
3. havent connected the sub properly to the remote lead
4. the stereo has to be switched off then remove the face i.e. the stereo constantly on standby
5. The sub and amp i bought are faulty (but doubtful)
6. Dogdy battery
what you lot recon
gonna need a current reader to test all the possibilties
gonna be a long weekend!!!!!
KarlM
Post by KarlM »
double check all your wiring - including the earth.
Failing that there could be something more sinister - take it to your local specialist (theres only so much we can advise without seeing the car)
pettsy
Moderator
Post by pettsy »
usually there are two connectors betwen the iso and head unit, these are red and yellow. they are switchable.
im guessing these may be the problem :evil:
