Polo 6r leaking
timmycr90
Polo 6r leaking
Post by timmycr90 »
Hi guys and girls,
I noticed a couple of puddles under my car last night and im wanting to pick your brains about what may be causing it, ive uploaded a few pictures for you to see its not water as it smells "eggy" and is greecy, I think it could be the brakes but not 100%. :(
http://s1293.photobucket.com/user/chris ... sort=3&o=0
http://s1293.photobucket.com/user/chris ... sort=3&o=1
any ideas would be appreciated.
Tooks
Drives: 2011 Polo GTI
Re: Polo 6r leaking
Post by Tooks »
It doesn't look like brake fluid to me, which is good.
But, it does look like coolant?
Has the level in the expansion tank dropped at all?
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Re: Polo 6r leaking
Post by greypolo9n3 »
correct me if im wrong but that looks like the drivers side inner wing?
Im guessing its your shock absorber thats popped
Tooks
Re: Polo 6r leaking
Post by Tooks »
Actually, that's a good shout from greypolo9n3, I hadn't appreciated that was the inner wing!
I'm guessing your car is red too? I'd assumed the fluid was red too, but realise now it's just taken the dirt off.
If the shock has leaked all it's oil, then it should be undamped/very bouncy when you push that corner of the car?
timmycr90
Re: Polo 6r leaking
Post by timmycr90 »
Hi guys sorry for the late reply. Yes it was frpm the drivers side inner wing. I took the wheel off and had a proper look, it does seem to be the damper thats leeking. Strange how its 10days since I lowered it. Thanks for the help. Guess ill have to find a strut on ebay :)
