less clearence on front right wheel
jlmmy
Post by jlmmy »
iv recently lowered my 6n2 with 60mill springs on sport shocks and theres no clearance on front right but front left is fine.
i measured the wheels and it seems the right is more forward to the front giving less clearance.
antone else noticed this? its the same on my old polo. i have now put 30mill springs and they ride no different to the 60 mill so have wasted another 100 pounds
please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
alexperkins
Site Admin
Re: less clearence on front right wheel
Post by alexperkins »
What tyres have you got fitted?
I think you must have something wrong with the front end setup. Its possible your subframe misaligned
jlmmy
Post by jlmmy »
well i measured from the centre of the wheel cap horizontally to the front bumper on two polo 6n2`s cars and theres neally an inch difference which is giving no clearance. it does seem odd tho. anyone running low with sport shocks on 16`s having problems with front right?
alexperkins
Site Admin
I was low on 16s on my first GTI and that had no problem
I do think your subframe may be off of where it should be and it's causing you to have an offset hub
jlmmy
Post by jlmmy »
ok ill check it out
cheers!
jlmmy
Post by jlmmy »
btw its on 195/40/16 tyres, couldnt find smaller ones
alexperkins
Site Admin
195/40/16 is correct. You shouldnt have any issues on those.
jlmmy
Post by jlmmy »
i ran this same setup of wheels and tyres on my other 6n2 and it was fine but that was on coilovers where this is on sport shocks. were u running coilovers mate?
alexperkins
Site Admin
For a period yes then moved to sports shocks. Havw you had the subframe alignment checked?
jlmmy
Post by jlmmy »
subframe is apparently ok, were u running the cheap yellow ones on ebay for around 150 pounds like me?
while iv got ur attention im trying to decide between ta tecknix brand new or used ap coilovers for same price of 190 pounds, which would u go for. i was quite happy with my old ta`s but the ride was firm. are the ap`s that much better?
alexperkins
Site Admin
No I ran h&r
The ta's and the ap's are much the same. Personally I don't like coils. More hassle than it's worth
I would personally save up and buy a good brand like eibach, h&r or similar
jlmmy
Post by jlmmy »
ok thanks for the input, neally bought some ap`s.
bought some 30 mill lowering springs the change for the 60`s that were on to try and get some more clearance and its no different, maybe 2 mill higher so that was another 100 with fitment thrown away. surely a 30mill springs should be higher than a 60?
alexperkins
Site Admin
30 should be a lot higher than a 60 drop
jlmmy
Post by jlmmy »
for some reason theres no difference, the guy who fitted said he measured the springs and they were differnt lengths but on the car theres no difference. wtf?
alexperkins
Site Admin
Depends what weight rating you got. If the springs are meant for a heavier/lighter car they will sit differently to how they would on the correct car
