where can i get a ross tech vag com
tommytse22
Drives: polo gti
Post by tommytse22 »
where can i get a cheap vag com for polo gti ? nearly 300 quid is a bit costy?!
Tony Boi 92
Re: where can i get a ross tech vag com
Post by Tony Boi 92 »
you can get cheap reps off ebay for like a tenner, but nothing like the genuine ;)
tommytse22
Drives: polo gti
can i changed code and stuff though with ross tech program ?
thank you
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
I have one of these.
http://www.dhgate.com/product/new-arriv ... |297809938
Works perfectly with the 6R. :)
tommytse22
Drives: polo gti
Mart!n-GTI-DK wrote:I have one of these.
thanks for the link!
so this tool work with the polo 6r? and work with ross techs software?
i want it to changed codes and teaks the car? or should i buy the real deal for that ?
thank you
If that rip off Chinese copy works as well as VCDS from Rosstech, then I'd expect Rosstech to be seriously worried!
Personally I'd expect that not to work fully like the legit versions of VCDS do, but what do I know?
As far as I know, VCDS Vers 12.*** will only work with genuine cables.
tommytse22
Drives: polo gti
RUM4MO wrote:If that rip off Chinese copy works as well as VCDS from Rosstech, then I'd expect Rosstech to be seriously worried!
so there is no way to get one of these and changed and teak settings? unless i buy from Rosstech ?
thats a bummer! i wonder if anyone is around essex with one that can let me use since im only going use it once and set settings and probs never will use again
